My e rake has gotten rather loose on my MT 2006 eclipse and I was wondering if there was any other way to adjust it than under the center console. I can’t get the nut yo go any tighter due to the lack of space and the handbrake is still rather loose
You can pull your rotor and you'll see the adjuster for the brake. It's a funky nut/bolt spreader. Once you know where it is, you'll be able to just do it through the inspection hole in the rotor with the grommet removed for the other side with a screwdriver.
What that adjuster does is spread the pads farther out, making up for worn material.
Odds are, your cables are stretched as well and causing issues too
