Lol I know it’s a silly question but I was just wondering because it’s not exactly in the FSM, it just says along the lines of “keep filling until at correct level”
I did a dump and fill (thank Mitsubishi Gods for a drain plug and dipstick on this trans) in November to further clean out the fluid from when I sucked it out before, sure glad I was able to clean that magnetic drain plug this time; it was a little overfilled anyway for a short period of time because I added some because of a very slow leak if it sits too long from the RTV’ed “gasket” that holds the valve body cover on from the factory, RTV is wearing out a little and seeps
Pulling the drain plug takes out around 6 quarts, I knew it was overfilled maybe half a quart so I added 5 which was all I had, and after getting it to temp, running through all the gears, with it running as the FSM says it’s sitting at the Low mark on the Hot part of the stick
Going to run it tomorrow with the scan tool connected to verify the trans temp is to the correct temp the FSM says (176F) and just keep adding some slowly till it’s at F
I only asked because if I could get a confirmation that it’s exactly half a quart from L to F then I could just dump half a quart in without mucking around driving it to temp and verifying with the scan tool etc
don’t like working on it in the cold haha
