2006 Mitsubishi eclipse
Yes I checked youtube. Yes I checked the forums on the internet and I am still confused about a few things. I take pride in learning to do things myself but I need some guidance.
- What do I need to remove from the underside and the top of the engine?
- What size are the 2 nuts for the lines going to the rack and pinion?
- What size wrench for the tie-rod nut?
- Also the ball joint has no cotter pin, is this normal?
- Are there any nuts/bolts that I should not reuse when installing the new one?
