Like I said I have a 07 Mitsubishi eclipse GS I just changed the water pump and timing belt and crankshaft sensor timed it right and still no start I thought it was the oil pump haven't fully took that off yet just wanted to know if I have to take the power steering pump off as well and could there be any other reason it's not starting just need a little help this is my fist Mitsubishi I worked on thanks again
Did you run any codes if so, what did you receive. Are you receiving fuel to the fuel rail or receiving spark? Are you receiving an rpm output when cranking? Was there any issue with idle prior to your no start. I had just resolved my own no start with my 4g didn’t get codes myself until I buttoned it back up and got a Maf sensor code then once I replaced that guy it finally hit me with immobilizer code being the fault never got the dash light for that. Hopefully you get it resolved
