So I've been recently having issues with my 2006 mitsubishi eclipse 4 cylinder car. It happened out of nowhere that I started getting a rough idle. Which showed up as a misfire on cylinder 2 when I plugged in my obd2 reader. I've tried fuel injector cleaner. Higher grade gasoline, replacing the spark plug, replacing the spark plug cylinder gaskets, and valve cover gasket, I've swapped coils (stayed as misfire on cylinder 2)
Then replaced the fuel injector with a remanufactured denso. Which only seems to have made it run worse. It's not leaking fuel, and the rom jumps up and down, and it only has a rough time while sitting. (It also seems to be bucking when I drive with the new injector) so I'm really stumped. Im assuming it can only be a vacuum leak at this point, though I can't find anything. So any advice would be very appreciated.
