2009 Eclipse GS / MT Just got the car back after a transmission replacement. At the shop, I noticed the unlock/lock feature on the car key was not working. Car started normally and the drive home uneventful. Thinking I had bad 1620 battery in the ignition key, I went ahead and replaced it. However, once I tried again the unlock/lock feature - nothing. Inserting the key in the ignition and turning, all dash lights illuminate as well as the windows work. Turn to start, the engine cranks but will not start. I'm aware that the key has a transponder that talks to the ECM but the question is, is the ECM receiving the transponder signal if the engine dash lights and accessories are working prior to cranking the engine? Basically trying to eliminate the ignition key as the problem when the car is returned to the repair shop.
