No it is not currently, should that be the next step?Is it tuned?
You should be tuned for a straight pipe, and you need a tune to make it pop, could damage the engine over long term thoNo it is not currently, should that be the next step?
Wow thank you for all the info, I’m new to all of this so I’m trying to learn. I think I’d want to go the “big pops sometimes and crackles more often” route. I’m going to see a tuner this weekend and he says he specializes in Mitsubishi. Is that a smart move? Or should I do something before going to a tuner?I'm guessing you want afterfire, not backfires. Backfires are through the intake, bad times.
Yeah, you can get a crackle tune. You can't run it with cats, and it can make your exhaust valves pretty hot depending how you do it. But there are other ways to do it that actually make it less harmful to the engine than not having it, by cooling the cylinders, pistons, and valves
Big pops always and bad for the valves: Timing gets set to fire a spark after the exhaust valve opens. Big bang, flames, lots of heat. 30 degrees after being a good point for big pops, it's where Audi does their DSG tunes to shift at WOT to cut power but not lose boost.
Big pops sometimes, crackles more often but only on a very hot exhaust: Lots of fuel added on over run, spark over advanced so there's no compression (factory is about +60 degrees off throttle to do that, but doesn't add lots of fuel). Downside here is fuel economy.
Also, a key factor is exhaust size. The smaller the exhaust, the more aggressive of pops you get, and better chance at a flame. The reason is because of added heat retention, and less volume of air for the flame front to have to travel through
well he quoted me 200$ but said he doesn’t know if the ECU would be compatible because he mainly tunes EVOs. Maybe it would be better to just go the fastworks route???If he asks for a standalone ECU or charges more than $500, walk away and get fastworks. Very few people can tune a 4G Eclipse on a stock ECU. Those who can generally use ECUflash, which is limited in features.
Fastworks lets you tune your own car afterwards as well if you wanted to adjust anything. They also support your car through tune updates as mods change. It also gives features like launch control
The definition files are just to be able to edit the tables on the ROM, without them, you can just read a ROM and then do nothing with itIf he doesn't have experience with the 4g of your exact engine/trans and year (different ECU definition per year and engine/trans) then he won't have any luck.
$200 is either a great deal or its someone who's about to brick your ECU (which happens if you don't have the definition files when using ECUflash, during the read attempt).
No never tried on my Eclipse because there are no definitions anywayHave you had success doing the read with ECUflash? Because there's a mountain of people who've had it brick their ECU, myself included, and have been multiple times when they "fixed" the bug causing it without fixing it
I also read that. But I'd also read it before. And before. I tested it after one of the fixes in 2016 that fixed it too. Next thing you know, back and forth with them for a few months, a month of them with my ECU, and it's finally unbricked. I had to bike to work for all that time as my car sat in the driveway, me desperately hoping every custom patch they'd sent me might fix it.No never tried on my Eclipse because there are no definitions anyway
Yeah I read that on the latest version they fixed it
That’s why I just went with Fastworks, but now I’m unable to login to that now and nobody will help me with the license. I think my licensed computers is maxed out because every time my computer updated it would generate a new computer ID to fastworks idk whyI also read that. But I'd also read it before. And before. I tested it after one of the fixes in 2016 that fixed it too. Next thing you know, back and forth with them for a few months, a month of them with my ECU, and it's finally unbricked. I had to bike to work for all that time as my car sat in the driveway, me desperately hoping every custom patch they'd sent me might fix it.
So I'd proceed with high caution.
There’s a 5 system limit and I guess mines maxed, Hackish can reset it butI've got no solution there. I've got it on two computers and haven't run into any issues, even changing operating system.
lol damn I thought this wasn't something I needed to worry about? I was still putting off my fastworks tune because of a bad o2 sensor, but that's replaced now.Have you had success doing the read with ECUflash? Because there's a mountain of people who've had it brick their ECU, myself included, and have been multiple times when they "fixed" the bug causing it without fixing it
With Fastworks it isn’tlol damn I thought this wasn't something I needed to worry about? I was still putting off my fastworks tune because of a bad o2 sensor, but that's replaced now.
Fastworks isn't ECUflash. Different software. Fastworks even has a recovery mode that lets you un-brick an ECU. Plus, step 1 with Fastworks is making a backuplol damn I thought this wasn't something I needed to worry about? I was still putting off my fastworks tune because of a bad o2 sensor, but that's replaced now.
