I have been having a rough idle and car bogs down when rolling widows up at idle. Looked at live data and saw my long term fuel trim was at 12 and when I tried to reset it said no communication. After I replaced my factory battery to body ground that had broke it let me reset the values but the long term values haven’t changed from 0 in almost a week and now live data loses communication I’m at a loss for what could cause these issues as I’m not great with electrical systems. Also drove 4K miles without throwing a code for misfire even though it apparently had an ignition coil that wasn’t even bolted in and that seems strange
Chase your grounding and power feed connection issues.
Inadequate grounding is a likely cause of all of that.
It has to be grounded engine to chassis, and chassis to battery. Your fix may have been too small a wire as well
I fixed it with a 4 gauge wire and sanded down the paint at the body but I’m not sure where my other grounds are
