1 - 8 of 8 Posts
Just as the title says ,i recently bought a 2006 eclipse, i knew there was a bit of work to do, one of the being that the radio presets do not save, was wondering if anyone knew the reason for that
Is it the stock radio?
I’m guessing it isnt, and some Bozo wired the radio up wrong and didn’t hook up the constant12v wire correctly, and used the switched 12v wire instead; so every time the key goes off the radio loses all memory
Its the stock radio :( the rocksford fosgate, they added a aux cord which im sure isnt included with the stock system so no sure if he may have messed up some wiring in the process
Discussion Starter #4
I also forgot to mention that the clock on the top resets as well, im not sure if thats a separate problem or what
1 - 8 of 8 Posts
