Remove the undertray if you have it
Unplug fog lights if you have them
Undo the bolts at the top of the bumper
Undo the plastic push pins that hold the fender liner to the front bumper
You'll find two annoying 10mm headed bolts. A 1/4" drive ratchet with a 6" extension works great for those.
Double check that you didn't miss any plastic push pins on top, or under the bumper, as well as any bolts up top (in the upper rad support area)
Pick up the bumper, walk straight away from the car with it.
Overall, takes about 10 minutes once you know how.
