1 - 7 of 7 Posts
Is there anyway to get your alarm not to go off if you manually unlock your car door. I bought a second key with chip starts car fine, in owners manual it ways alarm will go off unless the fob if used to unlock doors.? anyone?
I have a question for the remote programming :
I purchased a Mitsubishi eclipse 2008 w//o the keyless remote.
Also I ve got a remote on ebay and tried to program it w/o success.
The car key will start the engine but when I unlock the driver's door does not unlock the passenger door ( or lock the passengers door) the button to lock or unlock inside in both doors work.
At the same time when I unlock the drivers door with the KEY the alarm goes off. and the only way to switch off is to start the engine.
Does any one have an idea where the problem may be?
thanks !
I have the same problem with my 09 Spyder. When I unlock my door using the key the alarm goes off and I have to turn my key over in the ignition to make it stop. I have to use the key to unlock it bc my key fob doesn't work. Anyone know the solution?
1 - 7 of 7 Posts
