I have lost my key. I took the ignition out and got it to crank but it won't start. Is their something that needs to be grounded so it will start or should it start with a screw driver
If I get another ignition with a key . Would that match up and work...You need the NFC transponder from your key fob or else it won't disable the immobilizer
So how do I hook a NFC transponder upIf I get another ignition with a key . Would that match up and work...
