Hi I've been getting the code P0421 and low gas mileage. First thing I checked was if my spark plugs were fouled up. When I checked them, all my spark plugs had oil. So I replaced the valve cover gasket and spark plug well gasket thinking that might fix the problem. I erased the code and drove the car for 100 miles and no code popped out but, when I checked my spark plug wells again there is moist building up again and a little bit of oil. It also kinda smells like gas too. By the way, I tightened up all the bolts with the torque specs assigned by the manufacturer. Any ideas why? Hopefully not a bad head gasket or valve cover.
P0421 is a catalyst code and has nothing to do with the spark plugs. It could be a fouled O² sensor, but chances are one or more of your cats is bad. Unfortunately, replacing one of those is not easy and may be pricey.
Costly once manifold is done usually cats need replacing too, cost me $800 for new manifold and exhaust work when my cats were clogged . Next time im gutting everything lol
