Hi Everyone! I have a 2008 Eclipse Spyder GS and the engine went bad so I am currently using it for parts. I just picked up a 2007 Eclipse Spyder GS and noticed that the Multi Display did not have the compass and temp so I decided to swap it out with the one I had in my 2008 which did have compass and temp. I swapped everything over and it all worked great (I had compass and temp!). The next day when I started up the car and the temp did not have any numbers - it was just "--". I thought maybe I did something to the ambient temp sensor so I purchased another one and replaced it today. It is still showing "--". Are there any hints/tips/tricks to get the temp back? The compass and radio display portion of the multi display work fine. Thank you in advance! Ron
Super Moderator
Hold the Minute and Hour button for a second (I think 30?), it will switch to Celsius and do it again to switch back to Fahrenheit. Should fix it.
Thanks for responding everyone! Unfortunately, that did not do the trick. It just changed the F to a C (and back). Whether it was F or C, I still saw "--" where there should be numbers. What makes it frustrating is that it seemed to work when I first plugged it in, and then the next day I get "--". Any other suggestions?
Temperature Measuring instrument Clock Service Auto part
