1 - 9 of 9 Posts
Hey new comer here, i just got an eclipse 07 for free, and its basically mint too at 57k miles, a good deal in my opinion, and i just wanted to know if i can get this little slug to 200hp, or atleast like 180whp or something because imo its pretty slow, bordering prius power at like 130whp, but i have been looking through the guides these past weeks and know the basics like the intake, exhaust, headers, gt throttle body, AEM F/IC, and dyno tunes, but i have a couple of questions, like what kind of other upgrades do i need to have other than the ones listed in the guides to get it to 200whp. Also i wanted to know what kind of power the 4(??) speed auto transmission can handle, ive heard some info that it can handle up to 240whp, but i also read on some threads that it can only handle less than 200whp, just wanted to get some clarification on that. alright guys looking forwards to becoming part of this community
Is it up to all maintenance? Timing belt? Spark plugs, air filter, oil, filter, coolant, trans fluid, brake fluid, power steering fluid, brake pads, rotors, tires, serpentine belt, battery
Full system code scan and no codes?
Timing belt is a must
If you’re good there, first power mods to a GS Auto (I have one) is the RRE header, and the Fastworks tune
Yep No codes, maintained by the previous owner who was an older guy, barely drove it but still did maintenance and took care of it, also garage kept
The FI/C stuff is generally pre-dating fastworks existing. Flashing the factory ecu will give better results. Talk to Alex in the link below to get a tune
https://m.facebook.com/alex.kazmirchuk?tsid=0.8376426909736829&source=result
To hit 170whp NA on that auto trans is gonna be intake, header, exhaust, underdrive pulley. To pass that, you'll be looking at modifying a 4G63 intake manifold, a custom cam, and hoping it makes it that far. Both will hurt fuel economy. Alternatively, you could add a turbo. Alex also sells T3 flanged exhaust manifolds.
Overall though, it's the slowest starting point, and second heaviest option generally of the platform. It won't ever be lightning fast
Discussion Starter #6
with a gt tb, an rpw stage 1 cam, and a dyno tune with full bolt ons, what kinda power am i expecting, i have a budget of about 5000, but i dont want to trade this in for a gt since this one is such in a good condition
Discussion Starter #8
Alrighty, thanks saber! I might trade this in for a gt and go from there since this gs needs a lot of work to go up to speed.
If you can change a cam, you're more than qualified to add a turbo.
I'm a big advocate of turbo GS, it's why I built one.
That said, it you're staying under 300hp, and cornering ability or fuel economy aren't concerns, GT is the way to go. It'll out launch a GS typically as well due to the same properties that make them terrible in corners
1 - 9 of 9 Posts
