1 - 9 of 9 Posts
I bought my 4g Eclipse with the aftermarket projector headlights already in, and a bulb went out so I figured I'll replace them all! well after changing out 3 of the 4 bulbs, I notice the passenger side high-beam is missing the housing retainer (little metal clip that holds them in) and I have looked all over the internet to find a replacement and have had no luck! Has this happened to you? Where could I buy a replacement or what could I use to substitute the retainer for the time being?
I also planning on replacing all four ballast because one went out. Then I don't have to mess with anything headlight related for at least a year.. hopefully, I was wondering what kind of ballast you guys are using and how long has it lasted you? Someone had told me DDMtuning had good quality ballast, but they're $8 a piece... Is that to good to be true? I need a 12v 35w ballast.
Here's a link to the ballast -http://www.ddmtuning.com/Products/Replacement-35W-HID-Ballast
Stop bumping old threads about this please
The FSM is on tearstone
Changing a light bulb is probably even in the owners manual
Can’t get the headlight bulb out of my one housing either it’s just stuck damn good, it’s a TYC replacement headlight with regular Sylvania bulb
feels like there's a clip around it to me..
I can turn VERY slightly the silver box & light together but there's some ring around it that moves easier.. just can't see any docs about any retaining clip.
holy cow it's easier than that! just pull out slightly off the bottom where the wire harness is
1 - 9 of 9 Posts
