1 - 20 of 30 Posts
2011 Mitsubishi Eclipse GT
Hey, Ive wanted to change my oem headlight to this ---> Spec-D® - Black Dual Halo Projector Headlights with Parking LEDs
But the problem I have is that my car have the factory HiD xenon light and on all site ive checked, nothing will fit these type of bulb. All aftermarket healight I saw was for halogen only. So I was wondering if there would be a way to fit the xenon bulb in those headlight or if I really need to convert to halogen.
Yeah that’s the problem, if you had the factory HIDs, there are no compatible aftermarket headlight you can use as they’re all for the basic halogen bulb
And it’s unlikely you’d be able to get new OEM ones either as Mitsubishi discontinued literally everything for our cars
Thanks for the repply, is there a way with the wiring to fit my hid connector with these headlight ?
2007 Eclipse GT
Idk about that, I did find these ones, which are pretty much the OEM lights but black housings so they should work with any OEM lighting
Those are for non HID, it literally says that
I recently went to the H13 from factory Hid, if you need to know what connector I cut off and which wires I spliced to the 3 prong lmk
Sent from my SM-N960U using Tapatalk
I don’t think this works the other way around
The fuses are bigger for the HID setup and maybe the wiring
Going from regular to HID like that is a fire waiting to happen
I went from Hid to H13, but what works for me might not work for other people. 3 days driving with lights, no melting or burning from what I can tell, but will keep my fire extinguisher nearby.
That's fine
I said that doing the reverse of what you did (H13 to HID), would not be safe
Discussion Starter · #10 ·
Did you have oem hid? or it was a aftermarket hid kit?
I just bought a Silver 09 GT with the OEM HID , but its a bit foggy and the light output is dismal .
Please DM how you installed the spec-d , any issues you faced ?
1 - 20 of 30 Posts
