Could putting the complete stock exhaust back on possibly resolve this?
I just changed both my O2 sensors after getting the P0421 code. After test drive no code came back. Should the code come back on instantly if it is the cat?
Clovis do I replace the top and bottom on right side or just bottom?Trouble shooting~~~ Do you know how to use a Multi-Meter??
Depending how old the O2 sensors are on this cat, you might have some fun removing these O2 sensors. You will need penetrating oil, an O2 sensor socket wrench to remove the sensors and check continuity of the sensors. Either way around... you will most likely end-up replacing both the upper and lower O2 sensors. Bosch O2 Sensors cost around $80 each, give or take $10.00.
If you didn't stripe the threads on the cat go ahead and install the new O2 sensors, mind do not put the wrong sensors in the wrong holes, you need an up-stream sensor, and a down stream sensor. Remove the set code and take it for a test drive, if the code comes back... you have a bad cat.
You didn't waste your money when you bought those sensors. When you install a new cat, you should install new O2 sensors also!! The cat will cost around $700.00. If you do the job yourself, you better have a good tool chest. Labor for this job can cost between $400 to $700.
If you do require further information concerning removal of O2 sensors, removal and installation of the cat, just ask, we do have an Eclipse Factory Service Manual Link. You should bookmark this link, it will become your best friend... 2006 Eclipse Factory Service Manual – Tearstone This is a very large service manual that contains 47 books, so if you need help finding something, just ask.
