Damn. Well, if it's not too late, you can skip the injectors if yours haven't failed. They're not a common maintenance item. And if you're not changing the main bolts, you're in the same territory with head bolts. I've stuffed them back in before with threadlock. It's not that above board, but works in a pinch when money is tight. Just be sure there isn't oil inside the holes. I've probably had the head bolts off on my TT 6 times, and it runs up to 30psi boost. It's not right, but did work.
Oil pump, main and rod bearings, piston rings, a quick cylinder hone, new seals, new gaskets (don't use a rear main gasket, use RTV instead, same with the oil pan), timing kit (with water pump) and you can probably call it a day for the next 100,000 miles if your piston skirts and cylinder walls aren't ovaling
EDIT: This is all with a tight budget in mind to be clear. Sometimes working for 95% 100k miles and affordable beats 100% at 200k miles and expensive.
