Recently I have installed Brembo brakes from evo x (front) and evo 9 (rear)
Required :
1) New wheels (8.5w, offset 38) i.e evo x compatible wheels.
Don’t like spacers etc …
2) Brembo callipers, pads, rotors, hoses and calliper bolts.
Oem eclipse hoses are to short for such a setup. That’s whyI have used front hoses from outlander (for my front side, length = 590mm) and front hoses from galant (to my rear side, length = 560 mm)
3) Rear evo 9 rotors have centring diameter that differs from eclipse. I have created specific space rings to make the centring diameter 69mm as for eclipse.
4) Need some fitment work with front callipers cause their bolts a 14 m width and oem fist swivels have 12 mm, so the openings should be enlarged to 14 mm.
By the way the place of callipers attachment was polished by 2 mm for better fitment on fist swivels.
Wheel Tire Car Vehicle Automotive tire
Tire Wheel Car Vehicle Automotive tire
Tire Wheel Automotive tire Automotive lighting Motor vehicle
Automotive tire Automotive lighting Motor vehicle Automotive design Tread
Automotive tire Asphalt Fender Gas Automotive lighting
Automotive tire Automotive lighting Tire Tread Wheel
Tire Wheel Motor vehicle Automotive tire Locking hubs
