Relay underdash noise, any ideas on cause?
615 views 3 replies 3 participants last post by  mkl
#1 ·
I have a 2006 GS. When slowing down to a stop a relay clicks just before coming to a stop. Originally thought it was ABS or a loose heat shield rattle but sound is definitely coming from inside the car.
#2 ·
Since nobody has said anything...
The only advice I have is that your ETACS module is the backing to the interior fuse panel. If you're hearing a relay sound, it would be from there, and you could work it out from that point by pulling relays until you find the noisy one.
