Crank, dealership or junkyard. You can inspect yours first. But if you can see any scratches then the nitriding is done for, and it'll likely wear out in under 100 miles again sadly.
Rods, RockAuto sells OEM style ones. May as well get a timing kit and fresh oil pump there too. They'll also have gasket kits. I always go for a nicer head gasket like a Mahle than kits come with however
If you want to go stronger, I can get stronger pistons, rods, bearings, and studs for 700hp/1000hp FI builds. But being a GS sport it wouldn't benefit you as the auto trans is the weak point, not the motor. So it's a bunch of money to have a very expensive and higher maintenance engine than stock without any gains. Hopefully that sales pitch is as bad as I was hoping--it's not something I'd suggest, even if it pays my bills
If you want to go stronger, I can get stronger pistons, rods, bearings, and studs for 700hp/1000hp FI builds. But being a GS sport it wouldn't benefit you as the auto trans is the weak point, not the motor. So it's a bunch of money to have a very expensive and higher maintenance engine than stock without any gains. Hopefully that sales pitch is as bad as I was hoping--it's not something I'd suggest, even if it pays my bills.
Ok jus making sure to see if it would be worth it thanks for being honest 😂 but I found everything i need hopefully labor cost won’t be so insane or my parents will jus make me get rid of it thanks
