1 - 9 of 9 Posts
Club4G Admin
Description:
The SCM.1 Shift Control Module for the 2006+ Mitsubishi Eclipse, from BilletProof Racing, allows you to use the factory steering wheel audio controls to control the UP/Down shifting of the sportronic transmission.
Mitsubishi did not offer the onboard paddle shifters in the Mitsubishi Eclipse, so BilletProof Racing came up with the SCM.1 to accomodate those who wanted the convenience and racing feel of paddle shifters.
Operation:
The SCM.1 remains inactive while driving in normal auto mode, this allows the audio switches to function normally. Once the shift lever is moved to the Sport Mode, the SCM.1 becomes active and removes the audio controls from the radio and makes them active on the shifter assembly. The standard SCM.1 comes configured so that all three switches on the right side of the streering wheel are used for Upshifting, and all three swtiches on the left side are use for Downshifting. This can be reversed by the user and is detailed in the instructions. Also, the stock shifter can still be used at anytime just as it can be without the SCM.1, no systems other than the radio control are interrupted when the SCM.1 is active.
Here is a link to a short video showing the operation of the SCM.1...
http://www.youtube.com/watch?v=Ofu95y6uZHc
The SCM.1 can also be configured to your custom specifications. You could use the switches to shift up and down, as well as use a switch for NOS, or a boost controller, or any other application you can think of. Contact us for details.
Contents:
You will receive the Standard SCM.1 Shift Control Module pre-wired with harness and all connectors, 4 t-tap connectors, zip ties, instruction sheet and wiring diagram, as well as a 25min. Installation DVD which walks you through the installation from start to finish and shows everything in detail. The installation should only take about 20-25 minutes and doesn't require any special skills or expertise in electronics. Very straight-forward and easy to install.
Benefits of the SCM.1:
Ability to have both hands on the wheel during shifting in a race setting.
Allows use of individual buttons for different purposes, i.e. NOS, Boost, etc.
More cost effective than installing a stand alone paddle shifting system.
SCM.1 was designed specifically not to interfere with the stock systems.
The SCM.1 comes with a LIFETIME WARRANTY...if it fails to operate as intended due to no fault of your own, we'll repair it or replace it for as long as you own it! You won't find a better deal on an aftermarket product anywhere!
Pictures:
Available from the following vendors:
Eclipse MR
So their selling them for BrianJ or that is him?
Eclipse MR
I know the vid is him....
1 - 9 of 9 Posts
