It's pretty remarkable what an ECU tune can do. I've installed a cold air intake, gutted all 3 cats, installed a high-performance muffler, throttle body bypass, etc, etc. I've probably spent 30 hours crawling around under the car, replacing this, adjusting that...and then Stas (Stayer) comes along and does more for my car and in less than 1 hour, than all the time I've put into the Eclipse since buying it. The engine responds faster and more aggressively no matter what gear you're in or what speed you're driving at. All it takes is a muscle twitch and then a quarter-second later, you're pushed back into your seat, feeling the exhilaration of raw thrust wash over you as your speedometer passes the mark at which cops stop ticketing you and start arresting you.
What you will need for the tune:
- A Mitsubishi Eclipse, model year 2006 & later
- A Tactrix 2.0 OpenPort cable (Don't get a Chinese knock-off)
- A Laptop with Windows 7, 8, or 10 & a good battery
- A PayPal account to pay Stas for his hard work & ingenuity
- A strong cup of coffee to keep you awake as Stas is in another timezone & does his magic late at night (for us)
1. Download & install the OpenPort drivers & EcuFlash from the official Tactrix website
2. Download & install TeamView on your laptop & WhatsApp on your phone (for communication)
3. Contact Stas through WhatsApp. BE PATIENT! He is in another time zone
4. Have your car info handy (engine type, transmission type, model year)
5. Make sure your laptop gets a decent WiFi signal out in your car for the TeamViewer remote connection
6. Make sure that EcuFlash can detect your Tactrix cable & that the LED's on it are blinking
7. Close all unnecessary background programs & disable your antivirus temporarily
Basically, he will ask you to connect the Tactrix cable from your OBDII port under the dash to your laptop, and turn the ignition switch to on (without starting the car). Once he remotes in via TeamViewer, he will open EcuFlash, verify that its the latest version, select your car ECU type, and start downloading the firmware. Your car will make some clicking noises during this process, it is perfectly normal. Once he's downloaded the firmware, he will copy it via TeamViewer to his computer to analyze the data & make the necessary adjustments. Less than 10 minutes later, he was back with my tune. He transferred the modified file to my computer, loaded it into EcuFlash, & wrote the file to my car's ECU. Don't touch anything in your car during this process. I turned off my headlights, radio, heater, & disconnected all accessories from my cigarette lighter. When it was done, I waited a minute before turning off the ignition and removing the key. I waited another few seconds, and then started the car. Success!
What did the tune do for me? I have an '06 GT Auto. First of all, when in gear, the low, erratic idle from installing the Cold Air Intake went away completely. I didn't notice any difference in how the car sounded at idle, as I have a loud exhaust already, however it definitely felt smoother. Out on the open highway it's another beast entirely. It pulls hard no matter what gear I'm in or what speed I'm already traveling at. And with the Tachometer limit raised to 7000, you can downshift and stay entirely in MIVEC, further increasing performance. Stuck behind a minivan? No problem, the engine downshifts quickly & starts sipping fuel instead of guzzling it, and it's ready to wake up and attack the asphalt again at a moment's notice. It's just like a vehicular Jekyll & Hyde!
I rate the entire experience with Stas 10 out of 10 for speed of service, friendliness, patience, & most of all, quality of service. Thanks, man!
