1 - 5 of 5 Posts
Dank Meme Extraordinaire
Hey guys im planning on putting in a Pioneer AVH4200NEX CarPlay Radio system in my car. I figured while I am at it, I might as well install a sub since I will have everything apart.
What do you guys recommend for the sub? (and Amp)
Should I get the Rockford Fosgate sub and box or should I get something else?
I'd go aftermarket. I've got 2 12" MTX's in a sealed box, with a 1200 Watt Pioneer amp, and it sounds perfect. Not too much, doesn't drown out the other speakers. I'd just do some research on aftermarket systems to determine what it is that you want and need
I'm not trying to go crazy. I just want a reasonably increase the lower end, but I also want to use as little space as possible because I use the trunk often.
I have 2 10" jl wo in ported box does plenty i never have it all the way up, im 26 also so not really needing every ounce of pounding like competetion but does sound good with around 400 watts
1 - 5 of 5 Posts
