Trying to install a Pedal Commander
1K views 5 replies 3 participants last post by  charioteer
#1 ·
The space around the accelerator cable is very tight. Has a clip release that needs to be pressed while pulling the connector up. I can barely get one hand in there. Does anyone know a trick to hold the release catch open while getting the connector off?
#3 ·
It intercepts throttle signal, and lets you program it how you want.
If you know how to do that using Fastworks, please share, as Michael hasn't been able to crack that yet and nobody I've asked has been able to explain the formula used to determine throttle position in regards to the 4 throttle maps
