The 2006+ Eclipse V6 Single turbo kit is the first of its kind for the platform. Manufactured in the USA by Autocity Imports & KSR Performance we are tag teaming the first kit made for the vehicle! Base kits will include Manifolds, Turbo, Piping, Couplers, BOV, Wastegate, Intercooler, Cross pipe, and oil feed/drain lines. Image used currently is just a generic picture.
Please note that you will need a tune for the kit to run properly, Base maps will be available for the base kit at an additional charge*
The initial kits will be sold until May 15th at this price. They price may go up after as we get into the R&D. All kits ordered before the May 1st deadline will ship by end of June. After that we have a 4-6 week lead time.
Expected HP on base map is TBD but estimated to be 380-420 on 8lbs. Dyno sheet will be released once our test car is complete. Turbo has capability to run 12lbs
2006+ Mitsubishi Eclipse V6 Single Turbo Kit - AutoCity Imports
autocityimports.com
- 2006+ Mitsubishi Eclipse Turbo Base Kit Includes:
- Treadstone 6″-8″ Intercooler (Trimming of bumper and crash bar may be necessary)
- Choice of Wrinkle Red or Black Piping
- MAF Housing
- Black Couplers
- Tial 50mm BOV
- Tial 38mm Wastegate
- Comp Turbo 58-60MM
- EGR Delete plate
- Cross over pipe
- All Hardware and brackets
- Oil feed and drain lines with fittings (Customer will need to tap oil pan)
- 2006+ Mitsubishi Eclipse Turbo Kit Options
- Full 3″ Straight Pipe Exhaust to muffler w/ 4″ Outlet ($450)
- Custom Color Powder coat of Piping- any Prismatic Powder Color ($130)
- Upgraded injectors and Fuel Pump (Price TBD)
- Tactrix 2.0 Openport OBD with Mitsubishi adapter ($199)
- Base Tune Map ($700)
- OEM Mitsubishi 3 Bar Map Sensor – Required for Tuning ($299)
- Wideband AFR Gauge
- Boost Gauge
- Pillar Pod
The 2006+ Eclipse V6 Single turbo kit is the first of its kind for the platform. Manufactured in the USA by Autocity Imports & KSR Performance we are tag teaming the first kit made for the vehicle! Base kits will include Manifolds, Turbo, Piping, Couplers, BOV, Wastegate, Intercooler, Cross...
