A while back I changed my spark plugs for the first time and noticed some oil in cylinders #2 and #3. It wasn't an alarming amount and it was mostly up by the top of the plug and not at the bottom, so after a chat with my mechanic friend I decided it wasn't an emergency. I bought the valve cover gasket and spark plug o-rings from Rockauto, but they've been in a box because it's been 90+ degrees every day and I don't have a garage.
Unfortunately, this past week I've been noticing a weird smell while driving. It's faint and intermittent, but it smells like an old cigar someone left lit in the ashtray. I don't smoke, so I strongly suspect the valve cover itself may have busted a leak, or the spark well leaks have gotten worse. The only other thing I could imagine causing the smell is possibly the heat shield above the third cat touching down on the exhaust (the rattle is real, y'all) but I figure the gaskets need to be changed either way; one thing at a time.
I'd like to do this myself, but I wasn't able to find a how to. I might be using the wrong search terms. I know the valve cover needs to come off obviously and that seems simple enough on the GS, but one of the posts I found suggested replacing the spark o-rings is not simple and you need a rope to hold up the cylinders or something?
If there is a how-to, could someone point me at it? If not, if someone could run the process down for me I'd greatly appreciate it. I'm a noob mechanic (spark plugs and CAI install are the biggest jobs I've done) so the more detail I can get, the more confidence I'll have to do this on my own instead of phoning up my mechanic buddy. If anyone can help out I'd be very grateful.
