I have been looking into doing a twin turbo build on my 4g69. I am relatively new to building and I have no clue what parts to considering buying or where to start looking. I know kind of the general parts list but if anyone has a solid list that I could use as a reference I would be grateful.
auto will only handle like 250hp before it breaks, so you want something about that power (if you dont want to swap into a namual, which is expensive.)
16g turbo maybe? 8lbs of boost, something like that?
probably 3000$ or around that area
dont qoute me on that tho.
8psi on a 16g should be well over 250hp unless the setup is REALLY bad. 11psi did ~340whp for me (16g 10.5t, titanium)
One guy I talk to regularly could only pull 4-5psi on a similar sized eBay T3 turbo with his auto. For that power level, a GT running NA is a better go in my mind for most purposes, and will be endlessly more reliable than an auto trans being pushed to its absolute limits
