Not on me, and rock auto doesn't list it for the 6g75 any more
ok, now that I'm at my computer, Gates does have an RPM series belt that is close, 192 teeth, top width 30mm, 8mm pitch, 1536mm length, I guess it is a belt for the Mazda K8, which was also used in some Ford Probes, just a few teeth shy may work out with tensioning, I guess this will be on my shopping list towards the end of me getting parts. The timing belts for the DOHC 6g72 are way too long at 257 teeth
off topic, RPW now stocks billet oil pump gears for the 6g74/75 from Boundry Pumps, converting from AUD to USD shows a very modest commission on RPW's side vs directly buying, it might be mechanically similar or dimensionally identical to DOHC 6g72 oil pump gears, something to check out
