Hello everyone !
I just purchased an Eclipse GS 2011.
The detail with which I have been having problems, is that the dashboard lights are still on after the car is turned on, with the exception of the "Check engine". After scanning, it does not show any error code.
I have reviewed fuses and relays, both inside and outside and all are well.
I followed the wiring from the inner box and, I found a small green piece with 3 cables (two of them cut) and another behind black cut, near the rim driver side. I really do not know what it is for or what it is called that piece although, I think it is related to the lights and / or turn signal, the low light works normal (it does not change for high or fog lights) and turn signal does not work (neither hazzard ). Apparently, the previous owner will have made some kind of provisional connection to connect front lights.
Actually, there are two (or three) details, dashboard lights on and no high light or turn signal.
I hope to receive some feedback on the matter as I would like to know in addition to doing things by myself.
Greetings from Sonora, Mexico !
