WORKS Clutch Kit 1 - GS
[165.161] $499.00
Click to enlarge
Producing power is one thing... getting it to the ground is another. WORKS’ new line of clutch upgrades for the Eclipse GS is now available to help ensure that power is finding its way to the ground.
WORKS Clutch Kit CK1:
Ideal for the street-level enthusiast with basic bolt-ons seeking a clutch with stock pedal feel but with extra holding power. Not recommended for drag race applications.
- High performance street system
- 75% more holding capacity vs. stock
- Super-Duty reinforced pressure plate
- Sprung disc with steel backed organic friction material
Comes complete with:
- Pressure Plate
- Clutch Disc
- Throw-out Bearing
- Alignment Tool
Application: '06+ Eclipse 4-cylinder, 5-speed including GS and GS SE
*Available in WORKS blue or OEM silver finish
WORKS
WORKS Clutch Kit 2 - GS
[165.162] $549.00
Click to enlarge
WORKS Clutch Kit CK2:
Ideal for the weekend Road Race, Drag Race, AutoX and/or RallyX driver looking for additional holding power beyond the Clutch Kit CK1. This set-up will NOT increase pedal stiffness.
- Heavy-duty street & racing system
- Holding capacity: 115% over stock
- Sprung disc, steel backed w/ staggered Kevlar design
- Pressure Plate
- Clutch Disc
- Throw-out Bearing
- Alignment Tool
WORKS
WORKS Spin Lightweight Flywheel - GS
[166.115] $469.00
Click to enlarge
A lightweight flywheel reduces rotating mass for quicker throttle response for a livelier and faster revving engine. The WORKS Spin will make rev-matching on downshifts that much easier. While the technique for launching an Eclipse GS with the lightweight flywheel is slightly different, we have found drivability to be perfectly manageable (even with the notoriously steep hills in San Francisco) and any trade-offs well worth it. The WORKS Spin features a hardened center section and replaceable steel wear area for easy and cost-effective maintenance to make this the last flywheel you will ever have to buy!
Other Features:
- Bolt secured OEM ring gear
- 6061-T6 aircraft grade billet aluminum
- Replacable Steel friction surface
- Meets SFI Specifications
Application: '06+ Eclipse 4-Cylinder, 5-Speed Models Including Spyder
WORKS
[165.161] $499.00
Click to enlarge
- Pressure Plate
- Clutch Disc
- Throw-out Bearing
- Alignment Tool
WORKS
[165.162] $549.00
Click to enlarge
- Pressure Plate
- Clutch Disc
- Throw-out Bearing
- Alignment Tool
WORKS
[166.115] $469.00
Click to enlarge
Other Features:
WORKS
