Posting in a 3 1/2 year stale thread, let's see how this goes....
My airbag warning light is on. I am pretty sure it came on when I pulled the upper dash display and unplugged the Passenger seat light from each side of the display, although I'm not 100% positive that was the cause, or even if that would cause it.
What I'm reading here is that if I disconnect the battery, and put a test light between the two battery cables (wouldn't touching the leads together also do trick?) AND click the ignition (totally draining residual voltage in the electrical system) AND leave it unplugged for a half hour...then if there really is nothing wrong with the airbag system, that red SRS warning light should reset to off?
I'm not sure I have a test light handy, I may just hold the battery leads together...umm...while DISCONNECTED from the battery.
I'm going to go try it, soon about now, but I wanted to bump the thread and get some comments too. Report to follow.
