92K views 159 replies 72 participants last post by  fimbres.dacid12
#1 ·
this is just a quick thread about how i installed my aux cable i bought at the dealership for bout 25 bucks.
first just pop off the faceplate, gently pull from the bottom an should come right off, dont forget to unplug the connector to the hazard button.
next unscrew the four screws holding in the stereo.
then unplug these connectors so the whole unit can come out.
after that make sure to lift up the little retainer so that you can easily slide in the three pins.
the three pins go in just how you see in the picture, the red goes into the bottom right open slot , the white goes right above it and the black goes just to the left of that. so the only open spot is the third to last opening on the bottom.
next i took off most of the middle section, everything easily pops off, just remember to unplug everying.
then i basically just ran the cord along the right side tucked away from everything.
the cup holder is a perfect place to run the cord, just slide it thu and the top will still open and close like normal.
everything works perfect and sounds amazing! i reccomend this for everyone.
#7 ·
so I assume this is only on the RF system?? I'll check and see what my plug looks like...i realllly want an aux connection
#12 ·
nice iphone
#15 ·
This was the first thing I did after tint back when the .com site was around.
Note that it only works for the Rockford Fosgate 6 disk changer units. If you have the non-RF systems, your best option is an aftermarket unit.
#20 ·
NICE!
I have to have this. Do you have a part # for the dealer or a link to one on E-bay? I'm not sure what exactially what you installed. Just a cable or a RF modulator to go with it.
#21 ·
Found it... I think
MZ360135EX mits part #
Called my dealer and they have one in stock. So I'm picking that up when I pick up my car on friday. Yep thats mod #2 and I have yet to even drive the car. #1 short shifter ordered today.
#26 ·
Ok here are the instructions I got from my dealer. They have been great to deal with so far.
And the part purchased
If anybody needs a more detailed pic I can send the full size pictures by E-mail.
#28 ·
Just went to the stealership and picked this up about an hour ago, $28, but oh well.
Went home, literally took about 10 minutes. Thanks for the write up !
Works great as well
