Hi all, I just got a wideband gauge and looking on how to install it. Most older posts were a little bit vague and I don't want to fuck it up. What is the best source of power to power the gauge? Also what is the best placement for the sensor with my Y pipe as it merges the 2 headers a bit late (over the steering rack) and I have a valve that opens right after the Y pipe merges and so if I put the sensor in the exhaust before the cat I won't be able to get readings when the valve opens and if I put the sensor right after the valve I won't get readings if the valve is closed but I want to be able to see the O2 readings both ways so would it work if I put the sensor right when both headers merge? Or would it be better if I put the sensor on the front header and take it for granted that the rear header will be the same?
P.S: Saber check your DM
