Hi all,
I have been racing my 4G a lot and after reading the Import Tuner Magazine, I have realized I have been losing power after some laps in the track. Now I know why my best lap times always happen at the beginning of each battery.
I am planing to the following:
- Replacing the 50% cooling fluid for a 40% (already did);
- Adding Water Wetter in radiator;
- Change motor oil for a synthetic one (already did);
- Adding one of those products who make the motor oil work with less friction. Would Royal Purple be better?
- Installing the Fan Switch mod;
I would like your opinions and help with the following ideas:
1 - Putting an oil cooler (I have one, already, but I dont know if will make things better or worse since it lays in front of the radiator);
2 - Installing a larger radiator (as in RRE turbo GT). Do you know any brand/make/model which fits our GT?
3 - Putting some kind of heat insulation, over the header. I am going to buy a short header (as soon as RRE restart producing them) and order a coating on it (ceramic coating, any idea?);
4 - Lift the back of the hood 1-2 inches, in order to create a hot air exit;
5 - I have a Methanol Injection kit from my SDS Kit (which I am not using). Would this help?
Is there anything else I should do, such as custom hood with air entries/exits, any kind of device to conduct air inside, than outside the engine bay? My ECT goes to 220F after 5-6 hot laps, forcing me to make a cool lap. Some times, I get 228F. Currently I am using a audible alarm (setup with dashdaq) so I dont forget to make a cool lap. I have already burnt my 2G engine due to overheating.
Thank you,
Best regards,
Ziki
Thank you,
Best regards,
Ziki
