7.1K views 1 reply 2 participants last post by  Sabertooth^2
#1 ·
Hello Im new to this forum but I got a code u1108 on 2.4l Sohc 06 eclipse and this U1108 code came up I know it means Meter CAN timeout/Not equipped. But anyone have this problem and what was the solution. Thanks for anyone who helps :sad:
#2 ·
Did you hit a really bad bump, then this happened, and you lost most of your gauges too?
I had this happen. I unplugged all the wiring from the back of my ECU, made sure all the wires were pushed into the plug properly, plugged them back in, and haven't had an issue since
It's a communication error from the ECU to the instrument cluster. Wire on the back of the cluster may have alternatively come loose. Or your instrument cluster needs replacement. But check the plugs first
